Well today was a good day as the mailman rolled through the 'hood as I happened to be outside tinkering with the Jeep (as I do practically everyday) and he hands me a box from SpiderWebShade. Yes, it arrived! You can only imagine my giddiness (sp?) and the spring in my step as I trotted myself back into the house and yell at the ol'lady to show the new Jeep sexy-ness:
Don't let the little box fool ya there is some good stuff in there:
Attachment 707
Inside the box you will find the shade along with 3 small and 8 large Spider Balls:
Attachment 708
You will use the 3 small Spider Balls for the front center and then the two outboard grommets but not the corners. Start the install by
mounting the center grommet to the footman's loop on the windshield.
Attachment 709
Install both rear corners. Slide the ball through the top of the grommet then around the roll bar. Once installed, roll the entire ball underneath to hide it from sight. Make sure you loop under the seatbelt bracket with the bungee.
Attachment 710
Install both inner grommets to the outboard footman loops.
Attachment 711
