Got down and looked at it. I see the problem. They tapped into the factory door harness with the trigger switch and also into the relay. Going back there this afternoon so they can disconnect from the door harness and reconnect the wire from the dome light and just have the trigger wire going directly to the relay and only the relay. That should solve the problem
