To change the oil with the Sprintex unit, I removed the airbox tube from the throttle body. In the pictures I posted above, you'll see that the MAP sensor wire is in the way. You can either push it to the side or just unhook it. You still use the OEM filter and can easily get to it with the air hose out of the way.
