Attachment 1215
Here's what it looks like from above.
Attachment 1215
Awsome thread. You are toing to change to stainless tube for everything?
Keep it coming. Great info.
Im on the edge of my seat. Your going to bend that stainless pipe?
OK. I was able to get back at it today. First step - relocate the horn. The horn bracket (in an earlier picture) is mounted to the inside of the driver's side fender. Just forward of the mounting stud is another stud with a ground. I'm going to swap the ground to the original horn location, modify the horn mount bracket and relocate it to the forward stud.
Attachment 1224
Attachment 1225
The final mods to the horn bracket took a few trials (and errors). But ultimately this is how it went. You need to remove a portion (shown), re-bend the tab that holds the bracket straight and re-bend the end to turn the horn mounting hole 90 degrees. I was tempted to just cut the support tab off but thought better of it because it really does do a job so I kept it.
Attachment 1226
Attachment 1227
Attachment 1228
Like so:
Attachment 1229
Final shape:
Attachment 1230
Before mounting the horn I decided to move the windshield washer hoses downward so they would more easily clear the can. To do this I had to loosen the ABS platform bolt that attaches to the top of the fender. With this bolt out I was able to just move the washer hoses down to a clear area.
Attachment 1231
And the horn goes into it's new location. I could have mounted the horn much lower into the fender well. But I figured "high is dry" should be my philosophy under the hood.
Attachment 1232
Next I mounted the catch can. I removed the bracket from the can. I used the bracket and a center punch to drill a pilot hole for the bolt location. Then I used a step-drill to enlarge the hole in the sheet metal to fit the mounting bracket for the catch can. All of this will be de-mounted and painted or treated before I'm finally finished. First, however, I want to get it all to fit and work.
Attachment 1233
Attachment 1234
Attachment 1235
And the catch can finally goes in.
Attachment 1236
Attachment 1237
Attachment 1238
