No. Maserati uses a Pentastar block and lower end. Pentastar was born out of the Daimler-Chrysler merger that has since been undone.
I think you're right Pickles. Most if the gunk follows the head gasket.
Attachment 1440
And it looks like the mechanic cleaned the deck with a heavy hand. My concern, ultimately, is my inability to have confidence in the power plant. When i'm into boost at WOT up around 5500 rpm and higher i can't escape the thought that something is going to break any second. And unlike the manual trans guys I don't get boost until i'm in that range b/c the pcm forces downshifts all the way to second gear regardless of speed. So i'm screaming at WOT when the supercharger bypass closes.
Seriously, when all the parts are in for my hemi swap i'm going to drive with my supercharger and not intervene by lifting my foot and cutting boost. I'll do that for a few thousand miles and donate the motor to the "lab" for a teardown and inspection.
Boost at higher rpms is actually safer than boost at low rpms. With my manual transmission, I intentionally downshift to get into higher rpms and put the throttle down to the floor all the way to 6500 rpm. I've been doing that a couple times a day for the past 6 months and ~6,000 miles, including two very abusive weekends on the sand dunes. Staying in a higher gear, lower rpms, and trying to accelerate hard would both be more strenuous on the engine, and be less effective at accomplishing the goal of accelerating quickly.
Quit worrying, put the pedal to the floor, keep it there, and enjoy :)
I received my Sprintex supercharger Tuesday evening and will install this weekend. The kit looks good and very complete. I went ahead and did a couple of preparatory tasks to get ready. I labeled all of the misc. formed hoses, so I wouldn't have to dig through them during the install. I also trimmed the hood insulation and repositioned the auto transmission dipstick as indicated in the instructions. The last thing, and most significant, is that I connected the Diablosport Intune that is supplied with the kit to calibrate the ecm.... I'm glad I did. There was an issue with the tune not being "calibrated" to my ecm. I have a newer 2014, so the code wasn't updated yet to account for the new ecm calibration. However, Gary with Sprintex and Mike with Diablosport were quick to address the situation and everything appears good at this point. Mike was especially helpful and very responsive. So far, so good...
I plan to take some pictures along the way and I'll post my thoughts when I'm done. I'm pretty excited. More to follow...
^^That would be an AWESOME thread.
I would have to say tho, Ive pounded on the pentastar a LOT. I think it may surprise you when you try to blow it up.
PS. give me the when and where on the hemi. I want to come see that. Or we could go completely nuts and put a supercharged LS7 in it.. How deep are your pockets?
Very cool. I am interested in the auto shifting and dropping out of OD on little hills.
And I am interested in seeing Mr. Whiskers.
Can't forget the boss
