2 Attachment(s)
		Safari Straps...You're going to want to throw your hard top in the garbage.
		Ahhhhhh the Safari Straps, one of our favorites.  Safari Straps perform two tasks at once, first they calm the wind in your jeep when the top is off, and second, they look sooooo cool.  Even if you want to keep your jeep stock, the safari straps make it look great when the roof is off.  Its a driving expirience that is a lot of fun and others who ride in your jeep will also enjoy.
Installation is a snap, ours took one person about an hour to install, and once they were on we never wanted to put the top back up.  Safari Straps has a 14 day return policy if you dont like them, but the chances that you wont like them is very slim.  The construction is top notch, and the clasps are powdercoated spring loaded steel when they could easliy have used plastic. The clasps make the point of the high quality of the safari straps and the people who make them dont cut corners.
The straps are very durable and are UV treated not to fade from sunlight.   Ive seen older jeeps with safari straps and the straps are still black but the stock padding on the roll cage is noticably faded.  Our straps are 2" wide and cover are the full cage model.  We suggest that for its wind calming and slight shade it provides when stuck in traffic.
Attachment 36Attachment 37
http://youtu.be/gjl3iqpSq_0
