So I recently replaced my rear crawler joints on Tonka.what a world of difference.
Did you replace with new Krawler joints or did you upgrade to their Monster Pros?
I replaced my old system joint to there newest ones. they are way better design and they are greasable.
im trying to put up pics but Its not letting me. lol
Joints before the instail.
Instailled joint pics
are these pics from your phone? did you get the app to work?
Rexx19 they are from my phone but only some worked without an error and other problem is i can only post one at a time. that takes forever when u have like 20 to post.
only major problem i had was getting the old joints out of the control arms. but with a large monkey wrench and a large open end wrench on the jam nut i was able to break them free and get them out.
Yes they are very tight. I had to use a large crescent wrench and about a 15lb sledge plus my neighbors help. We placed the arms in a vise and almost broke the table it was attached to by the time we broke all 8 arms loose.
did you guys use 242 locktite when you put the ends back in?
I used loctite on the jam nut when setting the torque on it.
never seize on the threads that go into the arm and then locktight on the jam nut. and im using a marine grease in the joints.
what did you guys spend? do you have to do this every few years?
