Here are our videos,
POST YOURS!
POST YOURS!
Heres one with us using the RIPP Supercharger to climb rocks
http://youtu.be/YOB8kcaHODY
The embedded videos here have a big portion of the right edge clipped. They are showing up as squares instead of wide rectangles. I can't even get to the "YouTube" logo on the bottom right of the video player to open the video on the youtube site.
ahhh the ad is covering it. hmmmmmmmmm. Corrected.
Here we are blabbing about coil overs and flares.
Its also the first appearance of the 37" KM2s with the Weld Racing Wheels.
http://youtu.be/yJ1El7zHrSY
back at Rausch Creek, testing the 2.5 X-Factor
http://youtu.be/q9j3MCqKoJE
Here's a favorite.
Axle Cam showing of the RK Xfactor lift
http://youtu.be/A4r6nCjH6qA
Thats a cool video. how is the camera mounted?
what brand of camera is it?
The camera is a contour,
and I attached i to the rear axle with a hose clamp.
Here a vid about the LED lights we run....
http://youtu.be/EWH5PCJXUVE
Here's a MOAB Vid
http://youtu.be/AV8CjthYV_g
More moab in the On Location thread
Here's some more!
http://youtu.be/RFhZu1_FIIg
Im going to get fired for watching videos at work! LOL
Can you lay out the steps to post videos on here when you have time.
Sure, you go to youtube.com
click "share" under the video.
then copy the first option they give you. It should come up already highlighted when you click "share".
Then in the post you are trying to write, you type http://then paste the you tube link ...paces and then
When you post it, it should come up at the actual video.
Message me if you have problems.
Here's another SC Vid
http://youtu.be/RcjX9dQv4t8
Thats Ross from RIPP, (he's the brain behind the unit)
His dyno is a dyno dynamics if memory serves, and the number he gives in this video is UNCORRECTED. The JL uncorrected number was about 326, so we are right about the same.
That truck has bigger tires. Im starting to think tire size dosent mean that much with dynos.
Metal Cloak Flares!
http://youtu.be/EXSpxRQdKzc
Thats snarf in the above video...
Thread resurrected! more vids please!
