Results 1 to 10 of 14
    If you are following this nightmare, here is the most recent update. Yukon sent me a new axle all pressed together correctly.
    We installed it without a hitch, and now rather than the abs and traction lights coming on some times, they come on all the time. I didnt make it out of the driveway.
    I dumped oil over the berring before intalling it, so I may have splashed some oil on the sensor. Took it out cleaned it, put it back, same problem. Took it out again, more oil on it.
    Im going to let it settle over night, since im exhausted. and fire it up in the morning. Hopefully this problem will be over.
    My weekend Jeep hobby has officially bled into the week.
    Heres what Ive figured out. We changed all the axle components and the lights came on right away now. Im thinking, I've taken this sensor out 20 times now, i must have just really broken it.
    upon further inspection, it appears the tone ring is pressed in backward. Easy to overlook....The sensor does not overlook it. It freaked out right away. pics coming
    Here is the shot with the abs ring pressed on backward.
    Its got a wide opening on one side, and a narrow opening on the other.
    I realized it when I saw how far past the ring the sensor was. My heart broke when I realized I had to rip it all apart again.
Name:	photo 2 (11).jpg
    Pulled it out and had to cut the rings off. ABS ring, seal, berring,
    Pressed it all back together and as far as i know, it all works now. knock wood. I didnt drive very far.
    Dude...lights out now? Still? Been two days!
    I only drove it for 5 min once i thought i fixed it, then it rained for 2 days, and I hate putting the top up. So she sits in the garage.
    Now im gone for a week so dont hold your breath, Im pretty sure I fixed it tho, and this one goes down in history as one of the most difficult mods of my career. Not because of faulty gear, the yukon stuff is top notch.
    I had gotten the axles about a year before I installed them, and they went thru a move from one location to another. In the box come 2 axles for the rear. They are in the box opposite one another. The end of one axle sits right next to the tone ring (abs ring) of the other axle. During shipping or us moving it, the one axle bashed the tone ring on the other, nothing major, but one tooth was damaged and the sensor would freak out at high speeds as the one tooth would throw off the sensor's math.
    Then we did it again and the tone ring was pressed on backward. This i didnt realize until after install when the senor really went nuts all the time.
    Mind you, everytime you take the axle out you are risking damaging the bearings that will make noise. Also you are spilling oil on the ground right where you are working each time.
    So we put in and took out the passenger rear axle about 3 or 4 times. By the end, you are working in a puddle of oil trying not to damage the bearing....etc.
    Im glad its over. I know everything about axles now tho.
