Quote Originally Posted by Pete View Post
What do the wheel sensors cost? Were these the same lights you got when the tire wore through the wire of the wheel sensor? Can we return the wheel sensors if that turns out not to be the problem?
the first step now is to figure out which corner the problem is in. Once I get to the bottom of that, ill start changing out the sensors. i have an appointment monday.
