The drilling on the LOD rear bumper is pretty minimal. I believe I drilled three holes through the frame in total. The LOD instructions were pretty good; but there is definitely room for improvement which is the case for most any instruction set. I found no issues I couldn't figure out through a bit of reasoning. I got my holes drilled and proceeded to install the tire carrier.
Again same ridiculously good packaging.
Carrier bushings protected with a film/sticker.
A little grease on the pin and it went right on. Notice the small hole in the side of the cylinder for a grease fitting.
