Results 1 to 10 of 17
    you putting rigid's in those holes?
    Yes -they are already in. I took the bumper right off after that picture and installed them. You can see them a couple posts earlier. I did the posts in the order you SHOULD do the install, not the order that, in my impatience for the UPS man, made me do a bunch of re-work! I just wanted the bumper on. A couple days later I did the rigids. They are bright and great with my S-pod. Running the wire was easier than expected. I basically ran it along the top of the frame rail area and cleanly into the cab.
Name:	2014-04-11 19.01.23.jpg
    They look good, are they connected to your reverse lights?
    Nah - just to my last S-pod switch. If I need that much light backing up, its no trouble to reach up and hit the S-Pod Toggle for daylight.
