Results 1 to 10 of 56
    Garage pic is at 25ft. Highs and lows looked identical so you only get one pic. Pics in parking lot are hi and low beam only. No fogs and no camera flash in any pictures.
    Hi beams approx 100ft from ditch
    Low beams approx 100ft from same ditch
    Garage hi beams at 25ft
    Pics are pics...my impressions are:
    Install is easy, aiming is easy, price is identical to its direct competitors at most retailers so that's a wash. Cutoff seems okay, and the light is projected in a useable pattern. I'm happy with the output, it's certainly better than stock and comparable to the Hid's I had previously, though a different temperature (a little less white.). While I wouldn't suggest there are extreme hotspots anywhere there is a tiny bit of what i would call fragmentation of light on low beam right in front of the vehicle. I think it is from the small KC logo on the headlight lense. Apparently the logo glows in the dark but your on your own if you what to see what that looks like. I don't give a shit about such things and you can't make me.
    Quote Originally Posted by Anotheruserid View Post
    well done. Ill get my pics in the dark today.
