Well I can tell you that with the wider wheel base, I'm pretty amazed at how stable the thing is. I've taken some corners pretty fast and it is pretty rock solid. If there is a bump in the corner that is the bigger issue more so than the g-force/rolling factor. Don't forget, for the tightest of turning radius, that would be just parking lot maneuvers, so we're talking less then 5 mph here.
