Didn't have a chance to post a review after spending a day with the hard top off. Must say going topless is my preferred method now. This was actually the first time the entire top had been removed for driving. And to quote my 5 year old "this is the cool Jeep." With the top off the center armrest was hot enough to burn the skin. After installing the spiderweb shade the arm rest actually felt cooler to touch than with the hard top on. While you aren't technically topless with a mesh top of any kind this is definitely an improvement over being exposed to the hot sun on a 95+ degree day with 80% humidity. One thing I wasn't aware of and caused me concern when I purchased was the possibility of the two center grommets bouncing of the roll cage, Spiderweb shade thought of this and install a Velcro cover to under the grommets when the hard top is off. There was minimal thumping from the center section bouncing up and down. This could be stopped by running a couple of bungee balls through the sound bar screw holes and the grommets with a plastic dowel rod placed on top. Or one long bungee ball cord that would reach through both screw holes and the grommets and back around to the underside to hook onto the bungee ball. I hope that makes since. I am going to try both options this weekend if it doesn't rain. Overall dollar spend this is a good product. There are imitators out there, and while I haven't seen their products, I knew I was getting a good product with the Spiderweb shade vs the competition.
Thinking about running either cargo nets in the rear or the spiderweb shade cargo cover. Is anyone running the Spiderweb shade cargo cover? And what are your thoughts?
