Ok..my install took more than 3 minutes, maybe 30, but i"m a bit slower and deliberate in doing things. I went with the full 2 door shade cage. It goes from the windshield, over the sound bar to the top of the rear seats and adds two side panels for the area under the roll bar. Cool look and keeps the sun off the rear passenger as well. Also will keep the dog in the car if hes in the back.
There aren't specific instructions anywhere online for the full "shade cage" so I took some time to watch videos and get the concept down. Once I watched a couple videos I just got started installing it. From that point forward it was a breeze. Installed the front center, then front left and right, then the rear and in between. The side panels have no instructions anywhere online but were fairly self explanatory, as all the shade cage products are. The only difference is that there is one really long spider ball to go around a wider section.
What a great friggin product! Seriously, I'd buy it 10 times over. The shade from the sun is fantastic, but I can still see out. With the doors on, it also significantly cut down on the wind inside the cab for me. I'm not sure how much the side panels had to do with that, but I'm guessing they helped. I drove on the highway for 30 minutes and didn't have any issues. It also kept some light morning dew off my seats when I left the jeep outside overnight. Totally worth it just for that.
LOVE this product. Here it is in use when I was out wheelin yesterday.
I haven't verified it will fit on with the hardtop 100% as the side panels use two of the top's indexing holes for the bungee. If the pin pops in then i'm golden. if not, then I just remove 4 bungees and reinstall when the top is back off. TOO EASY.
I'm so pleased I have this with the summer coming up quickly!
- You may not post replies
- You may not edit your posts
