Results 1 to 10 of 18
    Here is the headlight out of the box.
    Its heavy in your hand, feels solid.
    I have the Xpel shield for it. I think I'll go video when I install it.
    Flickering
    If you have researched truck-lites headlights, You have read about flickering. Here is what it is.
    The JK's electrical system sends power to the lights in pules. With a halogen bulb, which has a slower reaction time than an LED, it will look like steady light. The more sensitive LED shows the pulse because it is more responsive to the power flow.
    Truck-Lite makes a harness that works like a battery to smooth out the power flow from the JK's power supply to the LED bulb.
    Problem solved.
Name:	photo 1 (10).jpg
