If you have researched truck-lites headlights, You have read about flickering. Here is what it is.
The JK's electrical system sends power to the lights in pules. With a halogen bulb, which has a slower reaction time than an LED, it will look like steady light. The more sensitive LED shows the pulse because it is more responsive to the power flow.
Truck-Lite makes a harness that works like a battery to smooth out the power flow from the JK's power supply to the LED bulb.
Problem solved.
