Well, got the lights installed on an Olympic bumper light bar. The lights were a breeze to install, but the light bar mount was less than easy. One the instruction are not well written. They say to remove the bumper and frame cover, both which are not necessary. You only need to remove the lower air dam exposing the lower crash bar. place the brackets in place and install the nut and screws from below. Having the frame cover in place helps hold the mounting bracket in place while you install the product. Doing it this way the bar can be installed in under 20 minutes.
Led light bars
H13 led bulbs on dim with Led light bars
H13 led bulbs on bright with Led light bars
you can see a small white blob in the middle portion of the picture that is a concrete building approximately 600' away, these lights are flood/spot combo. Overall impression I like how everything turned out, I may consider mounting the lights below the Olympic bar to provide some protection and give a lower profile setup.
