I love the build. Jesse (snarf) just did a full game changer so he can answer any questions about that. He hasnt done drive shafts yet.
If you go to tire rack, they show you the tire's weight. The lightest when I last looked was the BFG KM2.
wheels are also important. they need to be light to. BB's wheel tire combo is around 100lbs. They are the lightest 37's im aware of on earth.
Black Betty, Sweet Pea, Jessee's Girl, all wear bfg KM2s. Tonka wears Mudd Grapplers. That is a tire I'd avoid.
The Second Runner Up to the KM2 was the goodyear MTR thats a little heavier, but people say its more "true to size". If you get that im going to want a full review.
Everything is going to feel like a dog with the gears you have. Ignore that and make a good decision with the gear chart. You do not want to tear your truck's spine out more than once. You dont want wrrrrrrrrrrrrrrrrr sounds from your axles if a berring gets damaged, or a seal.
There is a lot that can go wrong that will leave nagging problems. So pick the right gear ratio the first time. And the right shop. Somewhere close to home.
Warranty- if you cancel it when its new, they give your money back. If you want a turbo or a supercharger, cancel it. Your already gearing, so the gears, carrier, axles, all have voided warranty.
