Hey Snarf77 !
Thanks for the feedback, very much appreciated.
I ordered the Metal Cloak 3.5" lift with the six packs and the full Metal Cloak wrap, front & rear bumpers, fenders, rails & rear LED lights.
Should be arrive in 4-5 weeks.
As far as the gears I looked the chart over again & Ross & WhiteRavenRR are right, the 4.88's is a better fit.
Snarff77, I'll go with the Yukon front drive shaft and chromoly front axels.
I'll also put the full Artec Axels in the front and back at the same time as the lift install.
I don't want to baby this Jeep, I want to be able to run it hard.
Supercharging/turbocharging, I'm following these threads closely, hopefully I'll be able to add one next year.
Any other thoughts?
Thanks again!
- You may not post replies
- You may not edit your posts
