Welcome to the forums!
I've heard good things about Tom Wood driveshafts. I'm only running 2.5" lift so I haven't had to mess with them.
Why the 5.13 gears? That will be a small pinion on a Dana 30 front axle. What's the biggest size tires that you plan to run? Again, 35" tires will be pushing it. I'm not saying that you can't go bigger. That's a whole different debate that I'm not getting into. Are you running a manual or auto, 3.8 or 3.6? What kind of wheeling do you plan on doing and how often?
There's more details in choosing the right equipment that you need to elaborate on.
The Metalcloak lift is a nice looking lift from what I can tell online. I would like to see one in person someday.
Again, welcome to the forums and good luck on the build. Post some pics as you go along.
Keith
