Results 1 to 10 of 449
Threaded View
  1. #11
    When Prodigy sent me the parts to hook up the PCV hose with a check valve, the instructions had me keep the road draft tube hooked up to the "make up air" vent on the engine. This was unacceptable, because air gets sucked INTO the engine through that tube now! That just seemed like a disaster waiting to happen (tires kicking up dust under the vehicle where the end of the tube is, submerging the tube in water, etc). I immediately ran out to an auto parts store and found a breather filter that I was able to rig up satisfactorily to the original make up air hose, but it was kinda ugly and temporary, so i didn't show it off. Prodigy told me at the time that they were still working on finalizing their solution to the make-up air side of the PCV system.
    I have since received a small breather filter (smaller than the hideous monstrosity I had rigged up) from Prodigy with a hose coupler that I believe is intended to be used to attach the filter to the end of the rubber hose that had previously connected to the air filter box. That just so happens to be the same curvy rubber hose that I sacrificed to modify the PCV hose (in the link at the beginning of this post) so I could add the check valve into the system while retaining an OEM look with the formed plastic hose.
    Jeff, that breather is hooked up to the hose that is attached on the drive side of the engine, that vents out to the atmosphere and hangs above the transmission? Thats that hose right?
