Wow, don't go over a 3" lift then, because then your drive shaft will hit the exhaust pipe (unless that was relocated.)
With the turbo installed, there is no portion of the exhaust UNDER the driveshaft anywhere, so there is no maximum lift allowed for exhaust clearance. I guess Prodigy assumes that people will lift their Jeeps.
