If I try that today, I'll probably crash because it's snowing here
When I recently recorded a data log to make the boost curve chart, that was full throttle in second gear from about 1500 rpm. I don't remember anything particularly bad happening, other than just generally not accelerating very quickly until after 2500 rpm.
It's been so long since I've driven with a stock engine that I can't tell whether it's slower, faster, or the same as stock in the low rpm range. Part of the sluggish feeling is likely due to relative comparison to how hard it accelerates above 2500 rpm, but I think there's still some issues with the tune in that area as well.
My data logs still show long-term fuel trims suddenly going extremely negative at 1500 rpm, then suddenly returning to more "normal" values around 2600 rpm. When accelerating lightly/moderately in 1st gear, especially with a cold engine, I feel a sudden decrease in power as I pass 1500 rpm, then a sudden jerk and surge in power right around 2600-2800 rpm. The severity varies with the amount of throttle I'm using, and the problem becomes fairly subtle when the engine is fully warmed up. The relationship between the long-term fuel trims and the acceleration behavior seems to close to be coincidence, and seems to me to indicate a problem with the tune. If tuned properly, the computer should not have to take away 20+% fuel in the 1500-2600 rpm range.
Have you gotten a custom tune from Prodigy yet?
The longer 1-piece silicone elbow that I have is a newer part that Prodigy now has custom ordered for the stage 2 kit. The shorter elbow that you have is a "standard" size (easy for Prodigy to obtain) that they used at first before getting the custom size. The shorter version requires a short metal pipe to be used as a coupler to attach a short extension of silicone hose to reach the turbo. You'll end up with 3 hose clamps in a row, right next to each other to connect the turbo, extension, coupler and elbow all together.
There's not much room for error, so you just need to get the coupler perfectly centered between the elbow and extension, get the hose clamps lined up perfectly and make sure all the hose clamps are tight. You also might need to double-check the angle of the compressor housing outlet compared to the angle of the silicone hose to make sure they are meeting each other in a straight line. The silicone hose only overlaps the compressor outlet just barely enough to use a hose clamp. Get that hose clamp right up to the very edge of the silicon to ensure that it is fully clamping down against the compressor outlet, rather than trying to squeeze the silicone off the end of the compressor outlet.
