Ugh. I saw that lift required on the first page and thought of you immediately. I just got the manual a day or two ago.
Looks like you've got a grip on it tho. I also would not go out of my way to install it on a jeep that is not completely prepared for it. Meaning cramming it into a truck without the minimum lift. God forbid you damage the pipe and then have some sort of improper air flow later.
Not the end of the world, but that will definately add some hours to your install. trying to figure out milimeters, and then try to predict axle travel...etc. That stuff takes forever. Then you need to work up the spine to test it.
Last thing you want is to be enjoying your turbo at speed and then a pothole really F's up your truck.
