This is what mine looks like
That does look like a problem
The fittings on the ends of your hose look like it may be possible to loosen, rotate, then re-tighten? Hard to tell from just looking at a picture. That hose/fitting is different than what I have. Definitely contact Prodigy about that to find out if they can recommend a way to adjust the orientation of the fittings, or if you need a replacement.
