Results 1 to 10 of 449
    I finally recorded some video of the Stage 2 turbo with the Precision upgrade. Enjoy the sounds!
    Nice job Pickles!!!
    Hey, a question for you. I see you have a 6-speed. Your shifts seem to be very quick in the video. I honestly don't think I could shift that fast because I literally need to pause a bit between shifts or it clicks/grinds on the way in. Do you have this same issue? Do you need to pause a second from 1st to 2nd, 2nd to 3rd, etc? I'm thinking that my manual transmission has actually been a little beat up. I'm not sure how the previous owner drove, but I know I drive hard AND, I taught my daughter to drive a stick using my Jeep. As you can imagine, there was plenty of clutch burning (given that at the time I had big tires and was under-geared) and plenty of grinding. Just curious if you can give some insight into how your Jeep shifts. Is it smooth? Can you literally shift as quick as possible or do you need to do like me and pause just a hair between gears so that it drops in smoother? (same question to anyone with a 6spd.)
