You still don't understand how it works do you.... The Air from the PCV valve tee is the stuff you are taking out of the engine.
You have another another breather line in the engine that pushes fresh air into the system to create the positive pressure.
No, it's you that still doesn't understand how it works. As I have already explained twice, the Prodigy catch can setup brings BOTH the PCV valve AND the breather port together into a tee, joining together as one hose, then into the catch can.
Learn how to read.
