Results 1 to 10 of 449
    I just realized while mounting up the turbo that there is no bracket welded onto the up pipe. Anyone know if this was a running change? Click image for larger version.
    Huh... I'll have to ask about this. It seems unlikely that it was accidentally left off. Now that I think about it more, I bet that bracket turned out to be unnecessary. The brackets on the down pipe probably provide plenty of support for the turbo.
    I guess the question that I should be asking... does anyone have an image of thier power steering box that i could reference after install?
    Alright,
    went scouring through the archives and found an image of your install, Pickles:
    This is what mine looks like
    You see how when one side is facing up the other is as well. If I align it to do one side face down and the other face up, I get a loop in the line.
    That does look like a problem
    The fittings on the ends of your hose look like it may be possible to loosen, rotate, then re-tighten? Hard to tell from just looking at a picture. That hose/fitting is different than what I have. Definitely contact Prodigy about that to find out if they can recommend a way to adjust the orientation of the fittings, or if you need a replacement.
