I do realize the limitations add-on kits have when it comes to space and so on and so forth. Prodigy has made a very neat package. That cannot be disputed. However, I question why they didn't wrap the entire exhaust system with insulation and add some insulation to the intake as well. I've been thinking about doing it for some time on my 7.8L Diesel Engine. I doubt I will see more than .5% increase in performance but what the hell right? Worked for Jack Burton???? However, I say put the shield around the intake and then add some cool tape to the intake side of the turbo some heat tape to the exhaust and see what you get performance wise. And if that doesn't suite you go for the gusto and put the MW-50 on it!!! Nothing says lovin' like a turbo with a drinking habit! Some times you just need a turbo that drinks like a sailor!
Where I would be concerned the most with a turbo's inter cooler that is air to air is on the low speed side of things. That is always where air to air units really show performance issues. However, you could put in larger fans and change the thermostats settings so they run at lower temperatures say 20-30F lower than normal that way you make up for the inter-cooler's added heat and disruption of air flow to the radiator. This would really help at low speeds.
As for the oil-cooler. I didn't actually know the Pentastar had a dedicated oil cooler that is a nice feature. Now, the only question is can it handle the added heat? Also how much did you increase your oil capacity to account for the turbo unit? That is the big issue, if you cooler cannot handle the extra heat it doesn't help to much. However, I'm betting it is just enough to get the job done at normal driving speeds. You might want to see if you can get a bigger unit for times when you are running the engine hard in an environment where cooling is minimal.
Have you put an Exhaust Gas Temperature Gauge in yet? That is a nice option to have. That way you can tell what is happening in the exhaust part of your system. I need to put on in my truck. But I'm lazy about cutting into the exhaust system.
