Results 1 to 10 of 449
    I guess this is more of a general question.
    I just realized while mounting up the turbo that there is no bracket welded onto the up pipe. Anyone know if this was a running change? Click image for larger version.
    Quote Originally Posted by ducatidesmo View Post
    Huh... I'll have to ask about this. It seems unlikely that it was accidentally left off. Now that I think about it more, I bet that bracket turned out to be unnecessary. The brackets on the down pipe probably provide plenty of support for the turbo.
    I guess the question that I should be asking... does anyone have an image of thier power steering box that i could reference after install?
    Alright,
    went scouring through the archives and found an image of your install, Pickles:
    This is what mine looks like
    You see how when one side is facing up the other is as well. If I align it to do one side face down and the other face up, I get a loop in the line.
    That does look like a problem
    The fittings on the ends of your hose look like it may be possible to loosen, rotate, then re-tighten? Hard to tell from just looking at a picture. That hose/fitting is different than what I have. Definitely contact Prodigy about that to find out if they can recommend a way to adjust the orientation of the fittings, or if you need a replacement.
