Results 1 to 10 of 449
    Quote Originally Posted by NOLAjeeper View Post
    Whats that breather you have hooked up to?
    That's the breather for the PCV system, which connects to the driver-side valve cover. This is my own temporary setup because the kit at one point had no solution for filtering the air that gets sucked in there (fresh air enters there to replace the oily air that is sucked through the PCV valve/hose into the intake manifold). Prodigy has since started including a breather filter that fits right into the original hose that used to connect to the air filter box. I hacked up my original hoses/pipes for the PCV system to experiment with some alternative setups. I actually have new replacements on order at a dealer so I can finalize my PCV setup and start using the new breather filter from Prodigy.
    Good news
    I have done a silly mistake by installing the MAP sesor plug the otherway around. Now everything thing is good.
    I didn't know there was more than one way that the MAP sensor could physically be hooked up. Please share details of how it can be accidentally hooked up wrong. We'll try not to tease you too much if it was a really stupid mistake
    About the water sound behind the dash , i heard it too.
    That's expected right after installing the turbo kit. There's probably air in the system from draining/refilling the cooling system. It should work itself out in a few days. You should check the coolant level in the radiator and the reservoir when the engine is cold and add more coolant if necessary.
    The water sound behind the dash likely has nothing at all to do with the turbo setup.
    In this case for me, it was clearly due to the heater hose connections allowing air into the system. All the clamps were a bit loose (because the hoses had compressed under the clamps over time), and the problem worked itself out after I tightened up all the clamps. I suspect NOLA's water sound issues will now disappear within a couple days. If so, then that's more evidence that the worm-gear clamps are not ideal for this application.
    If you have the water sounds AND no/low heat blowing out of some of the vents, then you have a clogged heater core that needs to be replaced. This is a known issue caused by casting sand leftover in some engine blocks. This is covered under warranty. Another possible cause for this is mixing HOAT and OAT coolant, which turns into very nasty/gooey stuff and would NOT be covered under warranty.
    If you get the water sound with every cold start, but heat works fine... check your coolant level (radiator AND reservoir). Burp air out of the system and top off the radiator.
    If the problem is now permanently fixed, then you just had some stubborn air in the system.
    If the total amount of coolant remains stable after you top it off, but the problem keeps coming back, then air is being introduced into the system somehow every time you drive, so you probably have a slightly loose seal somewhere (in my case, slightly loose hose clamps). Worst case would be a bad head gasket allowing some combustion gasses into the cooling system, but that would likely cause more severe problems.
    If the total amount of coolant is not stable (losing coolant), then you either have a coolant leak somewhere, or a bad head gasket that is allowing coolant into the cylinders, which is being burned off.
    The extension adapter provided by PD for the MAP SENSOR. I am referring to the connection between the extension adapter and the engine harness adapter which can be easily miss installed the slot looks identical either way.
    Ok my impression about the kit:
    It's good but i have an issues regarding the initial pick up. ie: full throttle at low rpm below 2000 will easily lend to a cut off in power theb gradually it starts boosting. Even once it reaches 4500 i can feel a power loss at 3rd gear Jeff can you confirm if it happen to you also since you have a manual transmission.? I used an app called dash command for data logging and discovered that the timing has been set to +12 for most of the rpm's and gears.
    My boost is reading 8.1 psi. I didn't install the AEM WIDE BAND yet so i can't determine the fuel ratio.
    A few possibilities I can think of:
    1) You don't have the latest tune improvements that Jessee and I have been testing. We received the updates as custom tunes. I don't know if the improvements have been pushed out to the official Prodigy tune on Diablosport's servers yet. The latest tune has big improvements in the lower RPM area.
    2) I have found that the turbo does not respond well to sudden full throttle, especially at low rpms. The engine seems to bog down a bit with sudden full throttle. From low rpms, instead of stomping on the throttle, try a smooth transition to full throttle. You can still quickly transition to full throttle, but just don't suddenly stomp on it. At higher rpms (4000+), it will respond more quickly to sudden full throttle, but smooth throttle transitions will always give you the best results because it allows for the turbo to keep up with your demands. I believe this is just a normal characteristic of a relatively large turbo. It doesn't bother me, because I prefer smooth acceleration transitions anyway (your drivetrain probably prefers acceleration transitions as well).
    3) The turbo can't really produce a lot of boost until somewhere above 2500 rpm. 1st gear accelerates quite well below 2500 rpm, but if you are in a higher gear, then you'll always get the best results from downshifting to get rpms above 2500 rpm if you really want to accelerate. That's one way the automatic transmission would be better. If you use a lot of throttle with the auto transmission, it will downshift. The manual transmission gives us the opportunity to be lazy and wish we could just accelerate quickly from lower rpms
    I think I need a more detailed explanation of this to understand it. Are you talking about driving steadily in 3rd gear at 4500 rpm, then stomping on the throttle? If so, then there will be an initial lack of power as the turbo spools up. This is boost lag.
    Now we've got 3 people making about 8.0-8.2 psi boost. Jessee increasingly appears to be the outlier with 9 psi boost! This really makes me want to crank the boost up to 9 psi with a manual boost controller to experience some extra fun
    I made my data log and ill send it to PD for the custom tune. My only concern for low RPM because i do extreme dune bashing with almost 15 jeepers in the desert. We climp high dunes. We sometimes race down to top as you posted couple pages back. This requires initial pick up (i am not talking about turbo spool but the vehicle tends to cut till it reach 2300 then it respond then the turbo spool.
    Regarding 3rd gear. Once i put full throttle while in seconds and shift to 3rd till it reach 4500 here where i feel the loos of power then it come back at 5800 ( the turbo sound different at that stage).
    This Friday i am going to the dunes to try it. Might shoot a video
    I confirmed with Prodigy that the new improvements to the tune are not yet available on Diablosport's server. Most of your issues should disappear once you can get the updated tune.
    Also, in deep sand, it's quite fun and relatively safe to rev the engine up and dump the clutch. Tires will initially lose traction for a nice 4WD "burnout", but as they dig down into the sand, they have more surface area contact with the sand and gain traction quickly for a nice launch that doesn't shock the drivetrain as if you did the same on dry pavement.
    I don't think I've experienced anything like this. I'd wait to see if this issue goes away with the updated tune before worrying about it.
    Yes! I still have not heard what my turbo and BOV sound like from outside the jeep as it drives by.
