Yup. But to say that it "vents out" above the transmission is misleading, because the engine actively sucks air IN through that hose any time there is vacuum in the manifold!
I'm reusing the original plastic breather hose, so Prodigy's hose is not involved in my setup at all.
Now that I think of it, Prodigy's intent with this new breather filter may be to simply attach it to the end of their breather hose that hangs above the transmission. This would at least filter the air coming into the crankcase, and would minimize oily smell by not being in the engine compartment, but I wouldn't want my crankcase vent down there when I'm splashing through mud/water. I really don't know what the latest official Prodigy setup is now with regards to the PCV system.
In case you are interested in obtaining new OEM hoses for the PCV system, a dealer should be able to easily find them in their system if you describe it to them as "pcv hose" and "make-up air hose". One was $15.85 and the other was $17.50.
