The extension adapter provided by PD for the MAP SENSOR. I am referring to the connection between the extension adapter and the engine harness adapter which can be easily miss installed the slot looks identical either way.
Ok my impression about the kit:
It's good but i have an issues regarding the initial pick up. ie: full throttle at low rpm below 2000 will easily lend to a cut off in power theb gradually it starts boosting. Even once it reaches 4500 i can feel a power loss at 3rd gear Jeff can you confirm if it happen to you also since you have a manual transmission.? I used an app called dash command for data logging and discovered that the timing has been set to +12 for most of the rpm's and gears.
My boost is reading 8.1 psi. I didn't install the AEM WIDE BAND yet so i can't determine the fuel ratio.
