Results 1 to 10 of 449
    Alright,
    went scouring through the archives and found an image of your install, Pickles:
    This is what mine looks like
    You see how when one side is facing up the other is as well. If I align it to do one side face down and the other face up, I get a loop in the line.
    That does look like a problem
    The fittings on the ends of your hose look like it may be possible to loosen, rotate, then re-tighten? Hard to tell from just looking at a picture. That hose/fitting is different than what I have. Definitely contact Prodigy about that to find out if they can recommend a way to adjust the orientation of the fittings, or if you need a replacement.
