Yes... my assertion is that either the claim is exaggerated, or RIPP just has a much better calibration at low rpms than Prodigy, or a mix of both. The difference in gains is too much to be explained by differences in efficiency of the RIPP vs Prodigy systems themselves.
Prodigy does their own tuning with the CMR software.
I do remember talking to either RIPP or Prodigy at one point, and they said they worked closely with Diablosport to develop some proprietary tuning capabilities in the CMR software so that they could properly account for boost in the calibrations. All the FI manufacturers work closely with Diablosport for CMR support. I don't know if there's some special calibration capabilities that are available to some manufacturers and not others, so it's tough to know whether it would even be meaningful to compare calibrations between different manufacturers.
I'm curious about whether the CMR software gives them control over the variable valve timing. I was just reading about how ideal cam timing is different at low rpm for a turbo, as compared to NA, to help the turbo spool more quickly.
Anyway, Prodigy is working on an improved tune. I know that low RPMs is an area they will put some effort into, because that have received feedback from multiple people about low RPMs feeling sluggish. It's possible that low RPM just was not a priority for Prodigy previously, so the hadn't yet put effort into optimizing it.
