Results 1 to 10 of 449
    Pickles is fierce with a spray can! It was a fun conversation we had that, in theory, the black painted intercooler is more efficient because the paint increases the surface area. We all know more surface area does mean more cooling...
    Ba hahaha... So by this logic, me putting on a big puffy down jacket should make me cooler, because the jacket increases my surfaces area, thereby increasing my cooling... Timma!
    Ha! All joking aside - He's just down for the sleeper look. I'm sure he could blow a mustang out of the water with those stock wheels and all that boost. I bet some minds have been blown at stop lights!
    Haven't had a chance to do that yet. Even if I did line up next to something decent, I wouldn't go for it because my launching skills are embarrassing
    Close... except not at all. Increased surface area is not the only criteria for cooling more efficiently. A big puffy down jacket uses materials designed to be a great thermal insulator. It fits loosely on your skin, minimizing direct heat transfer from your skin to the jacket. It is thick with a relatively flat/smooth surface, so it has a very low surface-area-to-volume ratio. That means it has a relatively high capacity for storing heat and relatively low ability to transfer heat to surrounding air.
    Radiator paint is specifically designed with materials to be a great thermal conductor. Unlike your jacket, it bonds directly to the surface for great heat transfer from the radiator/intercooler into the paint. The paint layer itself is thin (low capacity for storing heat) with a rough textured surface, so it has a very high surface-area-to-volume ratio, greatly increasing the surface area for transferring heat to the surrounding air. It's like covering the entire intercooler with tiny heat sink cooling fins.
    Then, as described in the "myth buster" video, the black color emits heat radiation more efficiently. On the flip side, it also absorbs heat radiation more efficiently too. If I had been thinking better at the time, I would have left the back of the intercooler unpainted. The radiator and A/C condenser are right behind the intercooler and are likely to be emitting more heat radiation than the intercooler has to give off, so the intercooler will absorb heat radiation from the back. Leaving the back unpainted would minimize this effect.
    [clip, clip]
    Oh Pickless... This is what I envision you look like when someone makes a joke ;-)
    Timma!!!
    Timma!!!
    That cartoon is hysterical.
