Results 1 to 10 of 449
Threaded View
  1. #11
    So are you saying that there may be something in the way pressure is equalized across the throttle body at part throttle?
    No, it's just the very different ways that superchargers and turbos work, and that the purpose/function of a supercharger bypass valve is very different than a turbo wastegate. A wastegate will never cause a sudden change in power delivery like a supercharger bypass valve can.
    Any time I get exactly what Pickles describe, a smooth, linear hard acceleration, and then I get what feels like a small blip in power, I've learned, it's gas with too low of octane or is not good enough
    Hard accelerations are actually smooth for me. It's the part throttle light/moderate acceleration where the problem happens. Also, the tune requires minimum 91 octane, and I'm running 93 octane (91 isn't very common around here).
