Quote Originally Posted by Charlie View Post
Timmy could you enlighten me as to how you connected your relays? I assume that the steps works when the doors are connected and also work when the doors are off.
I'm not sure I follow exactly on your question? I thought my write-up gave enough detail on the relay I used, the wiring I used, the connectors I used? Happy to help, but maybe get a little more specific if you would.
And yes, this solution will work with doors on or off. The problem with this solution when the doors are on is that AMP distinctly designed their solution to lower the steps only on the side that the door was opened on, and to retract as soon as the door is closed. By connecting to the dome lights, this solution will lower the steps on both sides whenever any door is opened (including the rear tailgate) and they will stay down until the dome lights go off. So as such, when you have your door and top on, it might appear the operation is a little goofy compared to what most people are used to seeing, however, the actually usage will still operate at the right time when you need them down to step on them. If you get the right type of splice though, it would actually be a snap to swap them from the relay solution here back over to using the wire for the doors. AMP included a nice wire tap that I had not seen before, that if utilized for both solutions (you'd have to buy more of course,) would allow you swap rather quickly, OR, you could get really fancy and put in a toggle switch that flip/flops between which solution you would use, that would be SAWEEEEEEET! Shoot, I may just do that. In fact, I may go so far as to put the button in the center stack set of buttons. If you did this, then in theory you could get away with just installing a single relay switch to control both steps instead of the two that I used (one on each side) and instead put your effort into installing the button. Ooooh, oooohh, ooooh, even better, you could get a lighted button that lights when the steps are down when used with the relay, then you'd have a nice visual (in addition to the dome lights being on) that your steps are down.
