So , switch aside, I took it to another shop today to get them to work off the dome light. They couldn't get it to work either. Printed out your step by step instructions and they still had the same problem. Steps would go down with dome light and then wouldn't go back up unless you manually turn off the dome light with the tree.
If you can take pics and post them here, I can probably help more. It's hard to help without seeing pictures of what was done.
You mention the steps would go up if you manually turned off the lights with switch on the turn signal stalk. So when the dome lights go off on their own, after a bit of time, the steps don't go up? That is odd, odd, odd. What is different with the lights turning off on their own versus turning off via the manual switch? I just can't see a difference. I mean, the lights either have power to them, or they don't! How can cutting the power to the lights via the switch produce a different result than the lights losing power due to the timer turning them off?
Anyway, get me a picture of the relay switch they put in, as best as you can given it will probably be in tight quarters. I'd say post it here in the forums versus sending it to me in a private message as obviously the more we can publish for all to see, the more others can be helped out by this.
