Well for starters, you can control both steps at the same time from one relay switch. So if you have the relay switch working on the passengers side, just attach the drivers side amp control cable to the same part of the relay that you did with the passenger side. You don't have to mess with putting a relay switch in on the drivers side like I did. Looking back, I should have just wired mine with a single relay switch that controlled both steps of the LED footwell light.
As for your actual question. You tap into the 12v lead to the LED footwell light for your signal for the relay switch. For the AMP step, you have to pull the driver's side signal cable over from the wire loom on the passenger side to the drivers side just like the AMP manual shows. In other words, get the entire system working according to the AMP instructions. Once you have done that, swapping from the signaling from the door signaling to the LED lighting signaling just uses the directions I've already posted.
