So I would basically need to buy a switch that is On / Off/ On?
Diodes? That's crazy.. Just follow my original instructions for linking your AMP steps to your dome light using a $15 relay from the store. Once you have done that, you are basically there. Then you have my instructions for dome light, their instructions for using the door signaling. Last step, toss a switch between the two options to chose which signaling you want to use, they both do the same thing just at different times.
Also, linking to your door lock won't work because door lock is momentary. You need something that provides constant negative grounding. The dome light provides constant 12v positive, that's why we use a relay switch. It receives that 12v positive signal and charges an internal magnet that in turn close the gate leading to a ground signal thereby providing constant negative grounding the entire time the gate is closed (aka the entire time the dome light is on.) One REALLY fun thing with this solution (for when the doors are off) is that magnet goes bonkers when the dome lights "dim" down, so it gives this little buzzing sound that warns you that the steps are about to retract. Once it's done buzzing, you have 2 seconds to either hop in or press the unlock button on your key fob to give yourself "bonus time."
Here, I whipped up a pretty Visio diagram to explain it better. You could get fancy and go with a three position switch instead of the two position switch I described here. Then you could set it so position 1 leads to the door solution, position 2 goes to nothing and position 3 goes to the dome light solution. By doing that, you'll get a way to deactivate the AMP steps from retracting entirely by putting it into position 2 (basically neutral because you never connect a grounding wire to one of position two's leads.)
