RJR Offroad has bushing that are "Guaranteed not to squeak" (for older jeeps) and they are poly. Personally..I'm not sure there is a real solution, just band-aids.
The control arms aren't hard to take loose. Youtube has several videos. The Teflon tape might just do the trick and do keep us in the loop!
Yeah, I'm guessing you just jack up the body to current height, unbolt the control arm and pull it out? Even then, I *might* only need to put the teflon on the body side of the control arm, as it seems like that is the part that is squeaking. Of course, if I'm going through all the trouble, might as well do both sides, right?
I'll have to check out RJR Offroad. I'm curious if they might have bushings that fit the Pro Comp arms? I'm guessing that every arm has a different bushing size requirement?
Either way, you guys can be certain that if I try the teflon tape and it works, that you'll be the first to know.
