Update... The control arms have grease points at the body side. I'm not sure if it was the install shop, or if they came from the factory with zerks, but either way, they have them at the body side mounts. Unfortunately, Engineer Johnny (see a fore mentioned video) didn't put the zerks in so they point down at the front, and put in 90 degrees zerks at the rear so you can't access them through the access holes!!! Stupid Johnny....
I unbolted one of the front lower control arms at the body and examined it. It sure seemed like this was the part making all the noise. It had an inner shaft on a ball that could move all around, surround by a poly bushing, and then the control arm. It was obvious it needed grease. So, given that I'm looking for a long term solution, and Engineer Johnny had the right idea but poor implementation of access, I just decided to drill new 7/32" holes, tap them with a 1/4" tap, and insert new zerks. Greased away until it was oozing out the sides, did the same for the other three lower control arms at the body, and then jumped on the jeep restlessly. No major squeaks!!! Took for a test drive, and so far, fairly quiet. I've never installed zerk grease points before. If I had known how easy it was after you bought the correct tap and zerk sizes, I would have done it long ago. Watch out squeaks, or you might get zerk'd!!!
So, for today, with sub 80 degree weather, my squeaks are mostly gone. I say mostly as the reality is you'll always have some from all the different bushings and articulation that goes on. But at least when I start of from a full stop, or come to a complete stop, my Jeep no longer announces itself to the entire world that I'm a brand new 2014 Jeep (sarc.) Hope this holds. If not, I'll just grease the sucker up again until the mount points are dripping grease.
Hope this thread has maybe helped others with their noise Jeeps.
