I just lifted the truck for the first time, the jack is 37 inches long, so its not super agile in the garage, I will say, a problem of a lot of jacks is that when you hit the valve, they just drop the car or truck.
our old craftsman did, (it also leaked inside 9 months of puchase) I thought it was just a cheapo jack, because it wouldnt let go, and then, all at once, the truck was on the ground. Too fast. As I researched, it turned out that a LOT of jacks have that same characteristic. Fast drop.
This one I can release very slowly. Maybe its a larger valve or piston, but the control is very good.
- You may not post replies
- You may not edit your posts
