Ok, here it is. Jessee's torque curve in both 3rd (blue) and 4th (red) gear:
If the pattern continues, I bet a 5th gear pull (which due to 4.88 gears, would be similar to a 4th gear pull on stock gears/tires) would result in an even earlier and higher torque peak that has a shape more like Prodigy's results.
