Results 1 to 10 of 47
    I like those wheels! The website says their for off road use only? So I'm assuming these aren't DOT approved?
    I would like to see how these hold up on a D30 axle.
    Caution! Do not fall into the rabbit hole of DOT approval and beadlocks! First..I dare anyone to try to find a law that says beadlocks are illegal or that if you drive on beadlocks, they need to be DOT approved. DOT deals mainly with OEM and commercial stuff..not so much off-road accessories. If a beadlock came as original equipment for a vehicle, then it would be DOT approved. Otherwise..not so much.
    I'm sure the wheels will hold up fine to the D30! The D30..who knows..as always..depends on how you drive.
