ID:	972Click image for larger version.
ID:	973Click image for larger version.
ID:	974Click image for larger version.
ID:	975OK, the next step is the removal of the 7(8mm) bolts that hold the manifold in place, and the 2(10mm) bolts on the passenger side of the manifold. Then 2 more 10 mm bolts on the bracket located on the driver side rear of the manifold. Now the manifold lifts straight up with a little guidance around remaining parts. Once off cover your intake ports with cloth or better yet painters tape, to prevent dropping something into the motor.
