ID:	958Click image for larger version.
ID:	959Click image for larger version.
ID:	960A week before the unit came I ran all of my 87 octane out and refilled with 93 so that part would be good to go for install. OK, here we go. First off we had to get the stock parts outta the way. I disconnected the battery, removed the stock air box and piping back to throttle body ( when removing the air temp sensor...it was noted in instructions to note how it was facing and to be careful not to damage it), engine coolant over flow tank ( not reused- new one provided) upper shroud, Plastic cover and foam pieces over intake manifold.
